ZETA converter design
zarif01
Joined Oct 5, 2024
8
I am designing a zeta converter using gate driver IC IR2110 in LTspice.
I have multi-phased it for current sharing across the switches.
The problem is my inductors L1 and L3. The power consumption of these two is very high.
I don't know what is causing it. Can someone please help me with it?
I have also attached the simulation file in the thread. Thank you.Screenshot 2025-01-27 013831.pngScreenshot 2025-01-27 014017.png
nologic
Joined Jun 22, 2020
11
I have also attached the simulation file in the thread. Thank you.View attachment 341287View attachment 341288
Can't make sense of your circuit, You have effectively placed L1 & L3 directly in parallel to each other. Also whats the purpose of D1 & D3 & R2 & R9?
Zeta Documentation below
https://www.ti.com/lit/an/slyt372/slyt372.pdf?ts=1737882695478
zarif01
Joined Oct 5, 2024
8
Got the Idea from this link:
https://ww1.microchip.com/downloads.../ApplicationNotes/ApplicationNotes/01467A.pdf
For the D1, D3, R2 and R9, I don't remember where I read it but, it was for DC stabilization or something like that. I don't remember.
I don't know why my Inductors are consuming this much power.
nologic
Joined Jun 22, 2020
11
But thats not what you've done. They are effectively creating a synchronous rectification and still only use 2 chokes. You are using 3 chokes. If i was you i'd start on the Zeta converter in the document i linked with 2 chokes and a single switch then once working look at bringing in the synchronous rectifier to replace the diode.
zarif01
Joined Oct 5, 2024
8
Yes I am using 3 chokes.
Actually, the first two chokes are parallel. I did this to lower the current stress from the switches. Other then that it should be a basic zeta converter.
I have also tried the simulation after removing the diodes and the resistors but the result doesn’t seem to be affected.
I have also done the simulation with ideal voltage controlled switches without using gate drivers. In that case the simulation was perfect.
But after adding gate driver, I am facing this inductor issue.
Ian0
Joined Aug 7, 2020
13,310
I don't think you can drive a zeta converter with a IR2110, because the source of the power FET has to go below 0V. I think it needs a P-channel FET.
This Texas Instruments application note says that the voltage across the first inductor is Vout when the MOSFET is off.
