assuming all bulbs r in working condition....I think you missed my point. Labeling the switches A,B,C will not tell you whether each one is on or off. My solution has the same problem. That is, you need a way to tell whether a switch is on or off from the switch room. If the initial state is all on or all off, it is not such a problem.
For example, assume the "warm" bulb switch is initially on. Not knowing it was on, you end up turning it off for 5 minutes, then change its state back to what will be "on". Another bulb is initially off, you change its state to "on." Now, when you go to the room, there will be two bulbs lit.
John
turn on switch A for 5 mins... the bulb meant 4 switch A will warm up due to the heating properties of the filament....
the rest is history.........
