Wouldn't three props achieve the same result as four?
No.Wouldn't three props achieve the same result as four?
Having four also makes the control algorithms for pitch and roll much simpler due to the symmetry. Though four isn't engraved in stone. Some have six. Other configurations also exist.No.
Two props are rotating in one direction while the other two are rotating in opposing direction. This to balance the rotational forces and this results in a net zero rotational force.
The general rule being that it's usually an even number of rotors ... right?Though four isn't engraved in stone. Some have six. Other configurations also exist.
From a practical standpoint, that is probably the case. Not an absolute requirement, but the advantage is enough in most cases that it would be hard to justify a different choice.The general rule being that it's usually an even number of rotors ... right?
With modern control software an odd number of blades is certainly possible. But why "fight physics"? Choosing an even number simplifies things, being naturally more stable.Here's a thing I wonder ... is using an even or odd (or prime) number of blades per rotor relevant? ... I mean, I'm sure that performance can vary according to parameters such as blade profile, diameter or rpm's or Reynolds number or whatever. But is the choice of using an even number of blades per rotor of any advantage now that CAD/CAM/CAE have become commonplace?
RIght ... why fight physics, good question. My point is that nowadays it's easier to come up with an unorthodox solution that would've previously been considered highly impractical.With modern control software an odd number of blades is certainly possible. But why "fight physics"? Choosing an even number simplifies things, being naturally more stable.
Fair enough. But are there any advantages of using an odd number of blades?RIght ... why fight physics, good question. My point is that nowadays it's easier to come up with an unorthodox solution that would've previously been considered highly impractical.
I saw some of those on a drone and it was pretty impressive. They are slightly less efficient, but much quieter and less strain on the blades. I imagine for marine applications it might cut down on cavitation damage too.The toroidal propeller is shingling example of what can be accomplished with a little imagination and modern tools..
Are you talking about the number of blades on a propeller, or the number of propellers?With modern control software an odd number of blades is certainly possible. But why "fight physics"? Choosing an even number simplifies things, being naturally more stable.
I think two-bladed propellors are the most common, but there are lots of three- and four-bladed propellors out there. Higher rotational speed favors fewer blades because it gives the air more time to recover from the prior blade passage (which is why propellors are more efficient at slower speeds). But more blades have the advantage of lowering the thrust loading on each blade. Everything's a compromise.
On real aircraft, there's everything from two- to eight-bladed propellors (including five and seven).
| Thread starter | Similar threads | Forum | Replies | Date |
Amazon Drones | Off-Topic | 19 | |
Flying Cameras—or drones have gone legit... | Off-Topic | 11 | |
Any expert in flying quadcopters, drones, with FPV goggles ? | Off-Topic | 6 |
