A simple solution is to acquire a reading from the engine flywheel with a handheld optical tachometer and then adjust the gauge accordingly.I've got a dumb question, since alternators are "usually" overdriven (at a higher than crankshaft speed) how is the alternator used as a tach signal?
| H | Need to control diesel fuel injector using microcontroller | Microcontrollers | 0 | |
| H | Control diesel fuel injector | Automation, Robotics & Control | 11 | |
| E | Designing an AVR for Diesel Generator | Power Electronics | 27 | |
Diesel fuel cell | General Science, Physics & Math | 4 | |
| I | Problem with diesel genset 50 kw 3 ph 400v 50hz | Technical Repair | 2 |
