Anyone care to download these and mail it to me as attachments.
I'll do it. I'm just hanging around anyway.Anyone care to download these and mail it to me as attachments.
I can't seem to view pdf's. It just freezes every time I click it.
All the complete manuals.
I'm guessing that the Auto / Manual switch changes the mode of operation between Auto start on power failure or not.I know that Paul.
I am thinking of renewing the whole thing.
So I bought 600 feet of 2.5mm Multi-strand DC cable to extend the harness.
I am thinking of making a descent panel for it.
How would you recommended I should go abt it.
I can make as in the Yanmar manual
In the panel u can see Auto / Manual switch .....What is that for ?
The is no Generator so what power failure or auto start. It's just a freakin fishing boatI'm guessing that the Auto / Manual switch changes the mode of operation between Auto start on power failure or not.
Sorry ....No go here.I'd be tempted to use an aluminum or steel box as it will give you something solid to anchor cable glands to.
l
So u think this panel is a bit over kill huh !.Another option could be to cut most of the original front panel out, leaving a lip all the way around to mount an infill panel on to. Probably less work on this onel
Ya ! That is what I was thinking, when I saw a the alternator connection.Just had another look at your pictures, I have a feeling that the item that you think is the tacho sensor is in fact the fuel shut off. The tacho is probably driven from an output on the alternator.
I was only guessing on the switch, I'm more used to agricultural and generators!The is no Generator so what power failure or auto start. It's just a freakin fishing boat
