Yamaha YDP-142 No Sound on Speaker and Headphone
35,327
Does it have to be expensive or would be a 90€ amazon one enough?
Like this
Yes. When you have nothing, just about anything will have to work. We have to look for the presence of digital signals going to the two DACs. Hence we will be searching for digital signals maybe 10 MHz or higher.
Are you prepared for the unfortunate outcome that you will not be able to fix this piano?
Caroexe
Joined Jan 8, 2025
45
Wouldn’t it be much easier to just buy another PCB and replace it with this one at this point?
Caroexe
Joined Jan 8, 2025
45
What is the price of a replacement PCB?
I did find only one seller but its around 140 USD + shipping. here
I probably can still buy an oscilloscope if you think it will determine if the pcb is dead or not. Getting a new PCB was just a thought if that will fix the issue for sure
Edit: I could grab something like this too if it is enough
Edit: if we need more than 10mhz this one could also do the job right? Could send my DMM back and use this one for both
Caroexe
Joined Jan 8, 2025
45
I just purchased this one in the hope it gets the job done, if not still a good item to have i guess. Could take a few days until it arrives, what would be the steps with the oscilloscope?
35,327
I was going to respond before you spend any money, but here goes after you have already taken that step.
You can buy and install a new board but there is no guarantee that the problem will be resolved. Only you can decide if it is worth purchasing an oscilloscope. Will you have a use for it afterwards?
Let's back up and make sure that we have checked off all the boxes.
Review all the symptoms and check what works and what does not.
All the functions appear to work except there is no sound from the speakers and headphones?
All testpoint voltages 1 to 7 (see post #36) check ok?
With the oscilloscope, you will be looking for the presence of serial digital data at the DAC, IC102, at R111, R112, R113.
Also at the Power Amp, IC IC103, at R115, R116, R117. At this stage, we don't care what the signals look like. We just want to see that there is activity. The signals are expected to transition between 0V and 3.3V.
What is your knowledge and experience using an oscilloscope?
How much experience do you have with reading and interpreting circuit diagrams?
What is your level at English language comprehension?
Caroexe
Joined Jan 8, 2025
45
I think I will use the oscilloscope and will need it in future projects so I don’t that it is wasted money at all. I did not use an oscilloscope before but I will try my best using it for the first time. I mean I am already this deep into it I might just learn this all a little bit deeper.
I have to wait a week for the oscilloscope to arrive so I will post again once it arrives and I did some testing. If you have any tips to give I am happy to hear them. And thanks again for all the help. I really want the piano to work again but if it doesn’t work at the end I will still be happy with what I learned. But I wish to learn and repair it at the same time :)
Caroexe
Joined Jan 8, 2025
45
Okay so a few days passed, I had to wait for the Oscilloscope to arrive and I was out of town. I did some measuring on the testpoints and I might have found something? Not sure, guess you will know better.
Here the results:
NO.Test PointJudgment criteriaMy measures
①+BMore than 15.0 V10.794V
②PVCCMore than 15.0 V10.794V
③+5V5.0 V ±0.2 V4.990V
④+3.3D3.3 V ±0.1 V3.288V
⑤+3.3A3.3 V ±0.1 V with AGND3.288V
⑥+1.2D1.2 V ±0.1 V1.196V
⑦-RESET3.3 V ±0.3 V3.285V
Test Point NO 1 and 2 seems off, right?
Edit: or are NO 1 and 2 off because I have the YPD-142 which uses DC in 12V instead of 16V?
Caroexe
Joined Jan 8, 2025
45
I couldn’t find R116 but other than that all points seem to get a signal. I did Auto check on all points so the settings did change as I was testing. First time using an oscilloscope. Here the results:
35,327
Your new OWON HDS242 oscilloscope looks good.
The noisy signal is likely because of improper ground on the oscilloscope probe. But this is not an issue for the information we are seeking. Where is the grounding clip of the probe connected?
Your next test point is at R104 and R105.
You need to press a note or play a demo tune while probing.
Caroexe
Joined Jan 8, 2025
45
Thank you!
Ground was connected to AGRND Point on PCB but i switched it to a corner point in this testing. I played a demo song while testing. Signal looks normal? Again I clicked on Auto to apply the "correct“ settings.
Here for 104
And here for 105
also I did some testing around while waiting and checked with MIDI if I get any signal when pressing the keys which worked flawlessly so keys are again working fine, just to make sure
35,327
The traces you showed in post #50 appears normal to me, except for the noise (but ignore the noise for now).
I cannot access your pictures from R104 and R105. All we are looking for is some wave transitions at R104 and R105.
Does the MIDI output work, i.e. you get proper notes played on a MIDI device?
Caroexe
Joined Jan 8, 2025
45
Don’t know why you cannot access the images but here a google drive folder with both clips.
I will try out MIDI tomorrow again
35,327
If your oscilloscope was set to 1V / DIV range as in the first photos, then I see no data being transmitted.
That would result in no sound output.
35,327
This is not going to fix the problem but just so that you know, your OWON oscilloscope is set to trigger on a rising signal at -38.0 mV.
The signal being tested is expected to range between 0 V and 3.3 V. Hence you want to trigger at a voltage level somewhere in between 0 V and 3.3 V. Setting the trigger level at 1 V will do.
I will have to study the circuit schematic to see where we go from here.
Are you able to confirm that a MIDI device is receiving musical notes?
Caroexe
Joined Jan 8, 2025
45
Okay I will change the trigger level while testing, thank you.
And yes the MIDI Connection receives all the notes when pressed so no issue there.
35,327
With all cables connected and POWER ON, use your DMM and measure the voltage between pins 1 and 3 at connector CN9. We expect to see +3.3 V.
While turning the MASTER VOLUME control knob, measure the voltage between pins 2 and 3.
We expect to see the voltage at pin-2 go the full range from 0 V to +3.3 V.
Caroexe
Joined Jan 8, 2025
45
So I measured Pin 1 and 3 and got 0.0001V so I get nothing. Same for Pin 2. So I guess we don't get any power there?
What's next?
