Working principle of a mosfet
jsnx
Joined Mar 17, 2022
21
Hello, I have a dumb question about the working principle of a normal mosfet.
When it is used as a switch, when we apply a gate voltage higher than the threshold it will output the voltage present at the source. It happens because it is working on its linear region.
When we use a mosfet in a buffer, we’ll sample the gate at the output because it is working in saturation.
is this reasoning correct?
thank you in advance.
ci139
Joined Jul 11, 2016
2,038
the 1-st one somewhat applies
the second one is a bit rushed - as the (presumably) non-inverting , non-digital buffer (in simplified interpretation) still takes (an easy to achieve) a threshold offset to the output voltage . . . while the word "saturation" would apply to the digital buffer only - but then (at the least case) it won't be a voltage follower - but more likely a double inverter (with several mosfets and amplifier stages)
the "normal MOS-FET" may be misleading - especially with the today´s fields of application and the variety available
https://www.google.com/search?q=mosfet+types+mode+of+operation
Ramussons
Joined May 3, 2013
1,572
An easier way to understand the working of a mosfet is to consider the Drain-Source as a "Voltage Controlled Resistor". The controlling voltage is the Gate-Source voltage. Depending on whether the mosfet is an Enhancement or Depletion type, we Reduce or Increase the D-S resistance by varying the G-S voltage.
38,948
When we use a MOSFET as a switch in the linear (ohmic) mode (left of the red line below), then a gate-source voltage well above the gate-threshold voltage is applied (typically several volts above) so that the MOSFET is fully on, and the source-drain voltage is then determined by the current flowing from drain-to-source times the MOSFET on-resistance.
When the MOSFET is used as amplifier or buffer, then it is operating in the saturation (active) region to the right of the red line below, where the gate-source voltage is just a little above Vgs(th).
In that mode the output is not ohmic but essentially a high-resistance constant-current.
