4 Pole Induction Motor Working Principle
BlackMelon
Joined Mar 19, 2015
173
I am studying the working principle of an induction motor. The attachment is a portion from Stephen J. Chapman's textbook (page 160-169). He proved the theory of the rotating magnetic field so well for a 2-pole induction motor from 160 to 164. However, on page 166, the author proposed a 4-pole motor but did not provide the similar proof. I would like to know how this configuration forms a rotating magnetic field and makes the rotor (squirrel cage) rotate. Do you guys have any good papers for this?
Thank You
BlackMelon
MaxHeadRoom
Joined Jul 18, 2013
30,741
Both 2pole and 4 pole motor operate on exactly the same principle, with the introduction of 2 more sets of poles, the mechanical time taken between them is halved, therefor the 2 pole motor rotates at twice the rate of the 4 pole, 6 pole and 8 pole will reduce the rpm in the same manner at a corresponding rate.
If you understand the 2 pole, the rest should follow..
