WORKING OF pH sensor circuit?
khizer ali
Joined Jan 10, 2019
21
I have attached pH sensor circuit? please someone explain the working , for acidic,basic ,neutral solution? also discuss the values of component used.
khizer ali
Joined Jan 10, 2019
21
Here is the circuit for pH sensor module which can be interfaced with arduino.This circuit is connected with BNC pH PROBE. It is working fine with arduino,but i cannot understand some of the items in circuit. Please someone explain me following things:
a)What is the role of zener diode in biasing circuit.?
b) What is need for biasing circuit.?
c)How this module will work for acidic and basic solution.?
Mod edit: convert .docx to .pdf
ericgibbs
Joined Jan 29, 2010
21,444
hi K,
The zener is to provide a stable voltage for the Biassing circuit OPA.
The bias is required to set the Bias OPA output to above zero volts, say Vcc/2
E
