Nothing is working for me, just going to order another kit, this time using 8038 function generator chip instead of XR2206
The circuits in posts #6 and 11 seem pretty clear.Does anyone have time to make a sketch?.
Let us know how that works out.Nothing is working for me, just going to order another kit, this time using 8038 function generator chip instead of XR2206
I have not tried the 8038 . Can't get hold of one. The lm324 i tried without success.Nothing is working for me, just going to order another kit, this time using 8038 function generator chip instead of XR2206
Looking forward to that.Does anyone have time to make a sketch?..... I'm too stupid to understand what is going on here and this is driving me nuts?
Why not just use two batteries, one for +9V and one for -9V. It will be much simpler.Does anyone have time to make a sketch?..... I'm too stupid to understand what is going on here and this is driving me nuts?
Because I am using an op amp that runs from a single supplyWhy not just use two batteries, one for +9V and one for -9V. It will be much simpler.
All op-amps run on single supplies, the only distinction is whether there is a "ground" reference somewhere in between. The point to using two batteries is that the middle connection makes for a convenient ground reference.Because I am using an op amp that runs from a single supply
Ua741 runs on a single supply?All op-amps run on single supplies, the only distinction is whether there is a "ground" reference somewhere in between. The point to using two batteries is that the middle connection makes for a convenient ground reference.
There are two power rails, just like any other op-amp, so yes.Ua741 runs on a single supply?
You're misunderstanding the jargon. "Dual supply" tends to mean that the reference voltage for an input signal can not be one of the power rails and must be constructed outside of the op-amp. The reference voltage is usually (but doesn't have to be) set to a point half way between the two power rails. If the power supply is 18V, you can call the power rails 0V and +18V and set the reference voltage at +9V, or you can call the power rails -9V and +9V and define the constructed 0V in between as the voltage reference point. All voltages are relative and you can call them anything you want. The fact remains that the op-amp has just two power pins, + and -.Not according to the data sheet my friend
Yes and no. With every op-amp, you still have to pay attention to the common-mode range. This is the range of input voltages that can be sensed by the op-amp and can be produced on the outputs. It's very easy to get bitten by your signal passing outside of the allowed input range. A "dual supply" amp cannot sense near either rail. That forces the designer to pay attention to the allowed range, and that's good practice no matter what op-amp you're using. Only "rail-to-rail" allows you to pretty much skip this chore. The 741 you mentioned, if powered at 5V, would have a common mode range of less? than one volt and that narrow range would lie somewhere near +2.5V. And yet we see plenty of folks coming here asking why it's not working for them.I'm so confused about split supplies and I have chosen an op amp that runs from a single supply......problem solved lol
