wireless transmission via graphite coil
Sumit Aich
Joined Dec 3, 2016
100
since graphite conducts. if spiral shape is drawn with pencil on the wall (thick , dark lines)
will a voltage difference appear between inner and outer end of the spiral when a varying magnetic field is switched on, normal to wall
my aim is to incorporate this into new mode of wireless data transmission
Sensacell
Joined Jun 19, 2012
3,787
While this sounds theoretically possible, I would have a hard time imagining the pencil line as a reliable electrical conductor.
Do some experiments with a pencil line- see if you can get a reliable and stable resistance reading on a multimeter.
How would you make the final connection to this pencil line?
Externet
Joined Nov 29, 2005
2,672
With proper continuity, the spiral should pick electromagnetic waves and produce a signal at its ends. A wired similar but for transmitting is used in concert halls, theatres ceilings or floors to feed second program/translated audio to hearing impaired or dedicated receivers among the public.
It transmits by feeding plain audio onto the winding, no RF carrier and it is called "audio induction loop". I installed one on the floor of a 400 seat theatre loooong ago.
----> https://en.wikipedia.org/wiki/Audio_induction_loop
