Why resonance improves wireless power transmission?
Mariemation
Joined Sep 26, 2016
18
I am trying to understand why resonance improves wireless power transmission, and I've found this in wikipedia:
"Because the Q factor can be very high, (experimentally around a thousand has been demonstrated[38] with air cored coils) only a small percentage of the field has to be coupled from one coil to the other to achieve high efficiency, even though the field dies quickly with distance from a coil, the primary and secondary can be several diameters apart."
Why only a small percentage of the field has to be coupled for high efficiency?
there is also this sentence: "provided the secondary coil cuts enough of the field that it absorbs more energy than is lost in each cycle of the primary, then most of the energy can still be transferred."
What does the part in Bold means?
Thank you!
danadak
Joined Mar 10, 2018
4,057
A high Q coil means it has very little energy loss. So takes less energy
transferred to it = more efficient in its use of energy.
The field is a 3 dimensional field, and the more the coil is inside this field the
more energy gets transferred to it. Think of dipping your hand into a bowl of
water, just the fingers not so much heat (energy) transfer, the full hand lots of
transfer.
Regards, Dana.
Mariemation
Joined Sep 26, 2016
18
Thank you for your response
But what i don't understand is this part: "only a small percentage of the field has to be coupled from one coil to the other to achieve high efficiency", I mean if only a small percentage of the magnetic field of the primary coil reaches the secondary one does this mean that when Q is high the secondary coil amplifies the power it receives, not just preserve it? Because if it only preserves it, then we can't say that the system can achieve high efficiency since only a fraction of the power reached the secondary coil in the first place.
panic mode
Joined Oct 10, 2011
5,306
your nightlight may be high efficiency even though it only takes tiny fraction of the energy that power plant produces. if it was not efficient, it would need much more energy from the grid (power plant).
If you visualize the spinning wheels as the LC circuits in synchronization with the RF energy as the circular motion of its rotation you can see how a small coupling of the B field (like a small spring shaft) can still transfer energy as distance increases beyond just inductive pure near-field coupling because the systems are linked and operate as one system. High efficiency is a misnomer here because even with resonance much of the energy is lost in transmission.
https://spectrum.ieee.org/transportation/mass-transit/a-critical-look-at-wireless-power
A good way to understand why resonance helps is to imagine the mechanical analogue. Suppose you wanted to transfer mechanical energy across a room, but all you had coupling the power source with the load was a long and very weak spring. You’d have to pump the end of the spring you were holding vigorously, moving it back and forth as fast and as far as you could until sweat poured down your brow. It wouldn’t be very efficient, but only with such effort would the far end of the spring wiggle a bit.
To make life easier, you could attach your end of the spring to a pendulum swinging in a wide arc, for instance. Now your arm wouldn’t hurt so much, and the far end of the spring would still wiggle. But another difficulty would appear when you tried to attach that far end of the spring to a mechanical load. If you weren’t careful, you’d find the waves of energy being sent down the spring weren’t being absorbed—most of what little energy that got to the far end would just bounce back. To solve this new problem, you could attach the far end of the spring to a second pendulum, one that was built exactly like the first. Now, all you would need to do is give the first pendulum some gentle rhythmic shoves until the amplitude of its swinging became large enough to get the far end of the spring wiggling in time with it. And those little wiggles would in turn have the right timing to get the second pendulum swinging. Despite having only a weak spring as the conduit, you would have transferred power across the room. Then you could do something useful with it—maybe smash a window.
Mariemation
Joined Sep 26, 2016
18
Hi nsaspook thanks for the explanation
Do you know an equation that shows the necessity or importance of working at the RF in this case? or do you have a document where the theoretical aspect is explained?
Thanks again.
Mariemation
Joined Sep 26, 2016
18
Thanks, what i meant though is why the driver frequency in the primary coil needs to be equal to the resonant frequency of the two circuits (transmitter and receiver), because in experiments we say that we need to operate at the resonant frequency in order to see this effect, not any frequency.
Thanks again.
The basic equations are the tuned transformer coupling equations normally used for RF.
https://www.minicircuits.com/app/AN20-001.pdf
For basic wireless power safety reasons we want the generated air-coupling fields to be mainly magnetic as to reduce possible human health hazards from RF electric field energy. This sets constrains on the physical to Electrical_length sizes of the resonator components to reduce the RF radiation (possible radiative far-field energy) component of the power transfer fields.
https://www.microsoft.com/en-us/research/wp-content/uploads/2007/11/tr-2007-143.pdf
The two physical limitations that still exist with this technology are the size of the device and the coupling distance between transmitter and receiver. The size of a coupling device is always a critical concern due to the inversely proportional relationship between the frequency and the size of the radiator. To get idea of this, consider this. Generally speaking, a half-wavelength dipole radiating in free space (without an external capacitors connected to it) that has a resonant frequency of 4 MHz requires a length of 37.5 meters. This may be too large for receivers to handle. However, this problem can be overcome by using a much shorter length of wire and loading it with a high value capacitor. Although the shorter length of wire increases the frequency, the high valued capacitor tunes it back down to the desired resonance. Research is continually being conducted on solutions to reduce the size of antennas and coils without compromising their performance. The coupling distance between the transmitter and the receiver of circular coils are limited by the near-field magnetic field strength (H) of the devices that decreases as the cube of the distance between the two (R3 ) increases. Based on the desired maximum distance that one would like to receive power, the magnetic field strength would have to be large enough to accommodate that distance.
