Window Comparator_Pull_Up Resistor_Comparator with Push Pull Output
hoyyoth
Joined Mar 21, 2020
531
Dear Team,
Do we need to use pull up resistor when designing a Window comparator using a comparator IC with push pull output(like TLV1805 ).
Regards
HARI
38,952
No.
But you can't tie the outputs together to get the AND function as you can with comparators that have an open-collector output.
hoyyoth
Joined Mar 21, 2020
531
No.
Thank you very much.
May I know In that case(But you can't tie the outputs together to get the AND function) how I will connect the outputs.
Regards
HARI
