MisterBill2
- Joined Jan 23, 2018
- 28,546
Another simple option would be to have both the normal battery for operation and then switch between the two external batteries in sequence. AND, keep in mind that if you have the computer clock speed set for max performance that is also maximum power consumption. It is all a tradeoff, which is important to understand. And it may be that you can't work that many hours away from mains power, no matter what you want.
