Here in this figure i want to know what role Q3 and Q4 are playing. I could have directly connected Q1 and Q2 directly with the micro controller....
I think what you are pointing out is the fact that the gates have no pull-up resistors. It won't work without them. The gates need to be pulled up to +BAT.Yes, if the collector current is zero then how Vgs will obtain the desired level
That's what we've been trying to tell you.I am not able to understand how Q3 and Q4 are working. Even there is base current but no collector current can flow. Collector terminal is connected to gate terminal of fet. so Vc is zero always. so this fet is not controlled by microcontroller.
I give up this circuit![]()
If you have ACDSee software then you can use it to adjust the contrast of the schematic.Your schematic does not have enough contrast. Everything is faint. I can barely see the details. I used to have a program to fix it but now the program is gone.
It looks like the collectors of Q3 and Q4 have nothing to provide a positive voltage so they won't work then the Mosfets also won't turn off.
Why answer a four year old question, with more questions?!I don't know why I am seeing this thread at this time, but ...
I think he is ok, just getting older and want to take a rest.it is always nice to see a thread where @Audioguru and @Ron H participated and - what the heck happened to Ron?
