Why the voltage is positive while the current is decreasing
skyline977
Joined Jan 14, 2021
29
Hi all,
The question is: enter image description here
The solution is: enter image description here
The formula used is: enter image description here
Why did he change the formula by putting an additional negative sign in front of the formula?
Why does the voltage increase as the current decrease?
The question and answer are from: FE Exam Review: Electrical and Computer Engineering 1st Edition by Myron E. Sveum Publisher : Professional Publications, Inc. ISBN-10 : 1591260698 ISBN-13 : 978-1591260691
The formula is taken from: FE Reference Handbook 10.0.1 By NCEES ISBN 978-1-947801-11-0
My attempt to solve the question is:
circuit analysis - Why is the voltage positive while the current is decreasing- - Electrical E...png
Wolframore
Joined Jan 21, 2019
2,619
You are correct it’s -16V across the inductor in relation to ground, but +16 at the negative terminal of the inductor, so if you draw a diagram with an inductor that’s in series with the source it would add voltage (notable when you place a load between inductor and ground). While this appears to be a negative voltage intuitively, it’s actually positive. I agree inductors can get confusing but very important. Just for fun figure out what happens if you reduced the time to 1uS.
38,951
An inductor always resists any change in current, or tries to keep the current moving in the same direction so from that, you can determine the voltage at the terminals for any conditions.aw89p[89+fg'
If it helps, inductance is the analog of inertia in the mechanical world.
MrAl
Joined Jun 17, 2014
13,899
Hi all,
Hello there,
It is interesting that in a pure electronic/electrical book you would normally see v=L*di/dt and that is evident in the various literature. In a pure physics book you may see v=-L*di/dt. I think the better way to write this however would be v=L*(-di/dt) because it would indicate a change in the direction of the current not just the whole thing being made negative.
I say this because in most of electrical engineering and control theory we see v=L*di/dt being used and that is because we assume conventional current is being observed.
Now obviously the voltage measured must be of the same polarity no matter if we use conventional or electron current flow, so if we use electron current flow we would have to make the current negative and this flips the sign so that the voltage comes out the same for both cases.
That seems to be a logical explanation and i will review some of my physics books later today we just got swamped by 2 feet of snow i have to take care of first.
skyline977
Joined Jan 14, 2021
29
Hi, I didn't understand what you meant by ".aw89p[89+fg'" in your reply or is it by mistake? I want to know everything you write.
skyline977
Joined Jan 14, 2021
29
Hello there,
Thank you. One thing I found is that if we consider the passive sign convention (acting as a load) or active sign convention (acting as a source), the signs would be reversed! which in the above example it's a load.
