Positive and negative output en voltage multipliers
Rufinus
Joined Apr 29, 2020
323
Hi everyone.
Talking with a friend, he told me there is a big difference when you make a voltage multiplier with + or with - output using high voltage and a transformer as sourse of AC.
The first one is with + output between point 1 ground and point 3 + output
The second one is with - output between point 1 ground and point 3 - output
He says when you use a negative output the high voltage can go trough the secondary of the transformer burnig it. I can´t see that. I´m missing something. Instead explaining me he said I should drwa the circuit to see it, but I can´t see it.
Could anyone help me?
Thank you
Ian0
Joined Aug 7, 2020
13,270
Hi everyone.
Thank you
Transformer insulation is not aware of the polarity!
panic mode
Joined Oct 10, 2011
5,240
there is a difference but only one... the polarity is different. ;)
if you look at top graph you can see that current draw is normal (slightly higher until each multiplier stage is charged).
output voltage and load currents magnitudes are the same.
i labeled individual stages (+,++,+++ and -,--,---) so you can observe symmetry at different points, and see how voltage scales up as more stages are added.
