Why led color changed from orange to red?
jorge.braque
Joined Mar 31, 2017
First of all i'm not an expert, i am not even close.
I had a defective backlight led (color green) in the vent knob of my car. I have no idea of the specs of the defective led.
So, i bought this led
with these specs
I soldered the new led and it lights up fine. The problem is that the led color from the center button changed from orange to red.
Does anyone has any clue why that might be?
Thank's again.
Dodgydave
Joined Jun 22, 2012
11,395
Its possible they share the same voltage or series resistor, and the green is pulling the voltage down, making the orange led glow red.
dl324
Joined Mar 30, 2015
18,439
Welcome to AAC!
Maybe i can use another led with more amperes with the same voltage.
It would be better if you traced the circuit so you don't need to guess what's going on and what will fix it...
The emitted wavelength of an LED depends on, among other things, current. At higher current density, it will shift to shorter wavelengths. The opposite would be true with less current.
ian field
Joined Oct 27, 2012
6,536
with these specs
Thank's again.
Once I was messing about with a blocking oscillator and red LED which turned orange when I turned the wick up - but I've never seen the other way round.
Any possibility a dual die LED is somehow involved? - Red & green die in the same package can produce yellow, or orange if you shift the balance of current in the 2 dies. If its a red/green LED; a drop in voltage could cut off the green slightly before the red.
GopherT
Joined Nov 23, 2012
8,009
If too much current is allowed to flow through a RED LED, it will look orange.
Also, photos of bright LEDs (red) can saturate a camera and appear orange in the photo.
