Adjusting Color Temperature and Dimmability of Integrated Bathroom LED Strip
stevendbos
Joined Mar 22, 2025
Hi everyone,
I’m hoping for some help identifying and possibly adjusting the color temperature and dimmability of my bright white LED strip in my bathroom fixture to make it look less like a hospital.
The lamp is an integrated fixture with a built-in LED strip. After opening it, I found the following details printed on the strip:
Model: AODO - 560mm x 30mm - 2835 - 152S
Color Temps: 2700K ○, 3000K ○, 4000K ○, 5000K ○, 6500K ○ (labeled but not selectable by power cycling or physical switch)
Voltage: 120V AC / 60Hz
Resistors: R1 6R20, R5 9R10, R7 4R70, etc.
Fuse: F1 1A
CRI: RA>80 and RA>90 labeled
Date Code: 20180824
1. Is there a way to adjust the color temperature on this strip, or could it be locked to a single preset?
2. Based on the specs, is this strip likely dimmable with a standard wall dimmer, or would it require a specific dimming controller?
3. Are there any hidden methods or wiring tricks to access the different CCT options?
bassbindevil
Joined Jan 23, 2014
924
My guess is that color temperature is determined by the SMD LEDs that are installed. I don't see inductors or transformers, so those LEDs are in series, and/or may consist of SMD COBs with multiple LEDs in a single package (I've seen that in a screw-in bulb I examined.). Drivers are probably linear constant-current. If you can identify the chip, the data sheet may say whether they can be dimmed and how.
You could add low-voltage LED strips next to the existing LED panels, or replace the panels with ones that have a different color temperature or more adjustability.
28,614
Given that the label I see has all of those different choices to be checked, now I am thinking that the assembly is not adjustable. So those LED tubes would be good in the kitchen, where actual correct color recognition matters a lot more..
