I was expecting to find that any 120VAC power source in our building would be in phase with one of the phases of our 480VAC. I was even basing a test fixture design for testing LED drivers on this. When I looked at the 120 and all three phases of our 480, I found the closest phase was approximately 45 degrees out of phase with the 120. Can someone explain why this is? My guess is the 120 was made with a 3-phase transformer using 480 on the primary and the 3 different 120 outputs produced on the secondary would not be in phase with either of the input phases. Is this correct??
