I am trying to make a PoE 802.3af solution. This are my schematics:
PSE:
PD:
The problem is that the power does not maintain. It only provides 48V for about 300ms, then it drops. Also, the above statement is valid when I remove the DC converter input capacitor; I tried a 22uF, 47uF, 22uF, 100uF capacitor, but every time I connect the capacitor, the PSE (LTC4263) does not supply power, instead it indicates low signature resistance by flashing the LED with a specific pattern.
This iare the oscilloscope capture of the voltage across D1 diode and PG output.
What is causing this behavior and how can it be resolved? What capacitor should I use?
Mods Note:
Please upload the photos to the forum and compress them to a clear resolution as 800x600 or 1024x768 .jpg file.
PSE:
PD:
Mods Note:
