ltspice simulation is good but circuit doesn't work real life
hhsting
Joined Apr 25, 2024
395
Hi:
Below I have a circuit where R6 is replaced by the actual led 3VDC at 100mA. 1N750 diode is a zener diode breaker down voltage of 3.8V or so to give constant 3VDC at the resistor R8 terminal. V2 varies from 0.1VDC to 1.5VDC. When V2 is above 0.5VDC the light shuts off and when V2 is equal to or below 0.5VDC light is on. V1 is constant either at 12VDC or 6VDC.
My problem is that the output at R8 is not coming to be constant 3.0 VDC. I get about 4VDC or above at the output. I blew one of BC5468 up actually popped. Maybe I wired something wrong or something not working.
Does anyone can test to see if the circuit works in real life? Maybe I wired it wrong somewhere. If it doesn't then how to correct it in real life?
