Why do you think my DC motor is pulsing on and off?
Status
Not open for further replies.
DavidAlexander
Joined Sep 22, 2020
10
Why didn't my text upload in my initial post? Anyhow, here it is
Need a motor for a pedestal buffer/polisher I'm building. I followed the directions but for some reason the motor pulses on and off for roughly 0.5 seconds and repeats. I wasn't sure if the 10kΩ potentiometer had something to do with it so I tried a 200kΩ and I'm still getting the pulsing.
Any ideas on what I may be doing wrong?
Minark's wiring instructions:
DC motor control:
MM23001C by Minark
DC treadmill motor:
Baldor
1.5 hp
90 volt
14.5 amp
4,800 rpm
Power:
110v AC
Many thanks,
Dave
DavidAlexander
Joined Sep 22, 2020
10
Test a lamp with the potentiometer? I'm not sure how I would wire that.
I've never set a current limit before and don't know how to do that.
I took the pots from another setup that works perfectly fine so there is nothing wrong with them. Anything else that might be wrong?
Anyone with any ideas I can try? Thanks
MaxHeadRoom
Joined Jul 18, 2013
30,815
The almost identical SCR bridge units sold by the popular KB Electronics require a plug-in resistor, selection value dependent on motor HP.
MaxHeadRoom
Joined Jul 18, 2013
30,815
I mean to use a 100w lamp in place of the motor, you should have a manual that gives you the set up procedure for the pots on the bottom row of the board.
DavidAlexander
Joined Sep 22, 2020
10
Didn't think I would get this many replies. Thank you to everyone for offering your ideas! I called the manufacturer of the speed controller and the technician told me to simply turn down the IR Controller and it would get rid of the pulsing. He said he get's that question all the time and it's always the IR Controller. I tried it and the motor works smoothly and is ready to be put to use. I also had a 25 year old controller from the same manufacturer that was hooked up to my vertical metal cutting bandsaw and the motor also pulsed and I left it alone for a long time. I turned down the IR Controller knob and the bandsaw works great! Man, wished I took the time to phone Minarik Corp a long time ago. :)
Again, thank you all!
MrSalts
Joined Apr 2, 2020
2,767
Your power supply is sensing an over-current situation. It retests every 0.5sec and shuts down, repeat. You need a smaller motor or a bigger (higher current output) power supply.
DavidAlexander
Joined Sep 22, 2020
10
It pays to read the set-up instructions, presumably you had them if purchased new, usually on the site anyway for most manuf.
As per post #13 !
It also is important to understand the question before you offer advice.
I stated that "I watched the Youtube video from the manufacturer and wired everything up as they said".
I assumed they told me everything I needed to know. <Mod:deleted offensive remark>
28,344
The picture of the controller module shows six adjustment pots and I am sure there is at least one of those for setting the current limit. Probably one also sets the maximum accellaration rate. If the motor draws excessive current then the controller will switch off until the excess is gone.
Status
