Slower start for an AC motor ?
Externet
Joined Nov 29, 2005
2,681
Hello all.
A 2HP / 3500 RPM plain induction single phase motor drives a compressor. Is there some passive circuit/trick to make it start slower ramping up during two or three seconds ?
MaxHeadRoom
Joined Jul 18, 2013
30,881
Why do you need the ramp-up?
That is unusual for a 2pole motor on a compressor, usually 4 pole !
What is the nature of the compresor? Vane? Piston?
38,943
One way, of course, is an NTC thermistor input current limiter rated for the motors running current under load.
Another is a delay relay that momentarily connects a power resistor of appropriate value in series with the motor input.
Love those deciBels!
Externet
Joined Nov 29, 2005
2,681
I prefer to attempt a 'gentle' start treatment to an antique compressor instead of stressing some components exposing it to a jerky jolt breaking its inertia from zero to 3500+ rpm in less than a second. Concerns about lubrication and cold temperature starts.
28,576
I have seen "soft-start" packages for induction motors a few years back. Mostly they are intended for larger motors than the one described. Soft-start is often an option on larger variable start drives.
For induction motors with an RPM triggered start/run switch, there is a potential heat issue staying in the start mode for a longer than intended time.
Wiith air compressors, unloading at shut-off is very common and always a better choice. The down-side is that it demands both a series check valve and a pressure release valve. To provide a softer-start speed ramp-up, a higher slip motor would be the obvoius choice. The compromise with a higher slip motor is lower efficiency, at least while it is slipping.
If we go back a few decades, lower speed starting was very common, often with manual starters. They are not at all common now, so there must be a reason for that. I suspect that it had to do with efficiency and cost.
Externet
Joined Nov 29, 2005
2,681
Thanks, Albert, good video. While the motor runs after the soft start; (99.9% of time) the current passes trough the triac. That part am not confident with...
Perhaps a normally closed push-switch could be implemented in parallel to the circuit to manually operate the ramp period.
MaxHeadRoom
Joined Jul 18, 2013
30,881
I would typically use an unloaded method, where there is either a manual valve or auto means of doing this,
What kind of reduction do you have between motor and compressor?
What is the nature of the compressor, Piston? Vane etc?
Post Photo?
38,943
That could be used to switch in a low resistance power resistor, similar to using a delay relay for that purpose.
You just have to remember to push the button before energizing the motor.
Externet
Joined Nov 29, 2005
2,681
Post Photo?
Compressor is 4 piston radial 4000 rpm from a 3500 rpm motor for 4cfm/3600 psi..
schmitt trigger
Joined Jul 12, 2010
2,288
Those motors have a centrifugal switch which at low speed applies power to the start capacitor and winding. As the rotor spools up and reaches a certain speed, the capacitor and winding are disconnected.
Neither component is rated to be powered up by more than a couple of seconds, otherwise they will fail.
If you delay too much the opening of the centrifugal switch, you will overstress the capacitor. It perhaps won’t fail immediately, but its lifespan will be shortened.
Externet
Joined Nov 29, 2005
2,681
Thank you all.
If 'unloader' means to start with no internal pressure builtup kept from the previous run; it has it automatic: purges pneumatically every time motor is turned off. The motor starts next run with less effort into a 'jolt' as there is no air kept compressed inside from a previous run
Am concerned in mechanical startup stresses of the compressor guts. The original motor was hydraulic; converted to electric now.
MaxHeadRoom
Joined Jul 18, 2013
30,881
Thank you all.
I thought it strange that a 2 pole motor was used in this application, I suspect that the original hydraulic motor was much less RPM! ?
28,576
NEVER count on a memorized sequence for any application that might need tobe done by somebody who has not been trained with the secret. THE REASON is that emergency situations DO HAPPEN, and that is not the time for a teaching session. Having to figure out a sequence to effect a life saving is a rather tense sequence, by the way.
38,943
What EMERGENCY SITUATION are you concerned about for this air compressor?
