SIM2 Domino 20 – Power Supply Repair – Looking for Advice
Hi everyone,
I'm looking for some advice regarding the repair of a power supply from a SIM2 Domino 20 projector.
Unfortunately, I don't know the full history of the unit. According to my neighbour, there was a spark when the fault occurred, and the projector stopped working afterwards. I couldn't find any obvious signs of burning or visible damage on the PCB, so I decided to start troubleshooting the power supply and checking its components.
So far, I have replaced the UC3843AN PWM controller IC and the original P5NB80FP MOSFET with an STP7NK80ZFP. I also replaced the main bulk capacitor with a new Samwha 150 µF / 450 V capacitor, along with four 47 µF / 50 V electrolytic capacitors. One additional small capacitor was replaced as well. However, the power supply still refuses to start.
The main bulk capacitor currently measures around 389–392 V DC. At the UC3843, I measure a stable 7.92–7.93 V on pin 7 (VCC), but only 0.257 V on pin 8 (VREF). Pin 1 (COMP) measures 0.821 V.
The UC3843 supply voltage is fed through two series-connected resistors, each approximately 150 kΩ. I removed and checked both resistors out of circuit, and their measured values are within specification. I have also traced the supply path and checked the associated components and connections.
I have also been investigating the LM393M comparator (IC102). Pin 8 has continuity to capacitor C130. The resistance measured between pin 8 of the LM393M and pin 7 (VCC) of the UC3843 is 20.12 kΩ. Between pin 8 of the LM393M and pin 8 of another controller IC, I measured 399 kΩ.
There is also an unmarked SMD ceramic capacitor, C202, connected between the UC3843 supply rail and GND. Its in-circuit resistance measures approximately 21 kΩ in both directions. I obtained similar readings around C203.
I have checked the diodes, the bridge rectifier, the MOSFET and other related components as well. Several components were removed from the PCB for testing. So far, I haven't found any obvious shorted or definitely faulty components.
I have also traced the primary-side connections of the main transformer, including the TR1–TR12 pins and the associated diodes and resistors.
Occasionally, when power is applied, I can hear a faint click or ticking sound, almost as if the power supply is attempting to start, but it never actually comes up.
At this point, the UC3843 seems to be the most interesting part of the problem. Its VCC voltage is stable at approximately 7.93 V, but the VREF output is only 0.257 V. I would also appreciate some guidance on the role of the LM393M and how it might be involved in the startup sequence.
I'm not particularly experienced with this type of switching power supply, so I'd be grateful for any suggestions on where to continue troubleshooting and what measurements or components I should focus on next.
I've attached a few photos of the PCB for reference. Unfortunately, I haven't been able to find a schematic for this power supply.
Thanks in advance for any help!
Hi everyone,
