What is the power of this motor ?
Externet
Joined Nov 29, 2005
2,682
What is SPL -Sound pressure level ? - The sticker shows 4 HP but plugs to 120VAC. Chinese ponies ? What is FL Amperes ?
38,952
Some half-size ones apparently, unless it's a 30A circuit.
I believe that's Full Load Amps.
15A @ 120V would indicate a maximum motor shaft output of about 2HP using a nominal 80% efficiency factor for typical, small, single-phase induction motors.
Had your dB today?
GetDeviceInfo
Joined Jun 7, 2009
2,286
‘Special’ indicates it is tailored to a specific task, in this case it would be a high torque start, typical of compressors. Dropping the start cap value will reduce start torque, but the extended start time will generate excessive heat within the windings.
ronsimpson
Joined Oct 7, 2019
4,899
My guess, this motor will do 4hp for 2 minutes, starting cold. It will not survive hours. I think it was designed to run the compressor at 25% duty cycle.
I have motors that state the duty cycle at full power, 1/2 power and 25% power.
28,612
Some of my power outlets are protected at 20 amps! #12 wire is code for 20amp service.
BUT I would NEVER BUY a direct coupled compressor package. I have examined a couple of them and I am not impressed with the quality. ALSO, 3450 RPM is too fast for a piston type compressor of the inexpensive variety.
38,952
Any outlet rated for 20A in the USA with suitable wire size and breaker, should have a NEMA 5-20R socket pattern with a T-slot.
Any appliance that requires 20A will then have a plug with a horizontal blade that will plug into the 20A socket, but not into a standard 15A socket (below).
Of course a standard 15A plug will still plug into the 20A socket.
