Some devices are required, some are installed in special cases or at all at will. Today we will look at such a detail as an RGB amplifier and try to find out whether it is necessary in Your particular case.
As you can see from the name of this module, it is used for an led strip that can change the color of the glow. Its main function is to strengthen something that may be weakened during connection and further use of the tape. What is it about? Why do I need an RGB amplifier?
