Hi Martin. I actually inquired about your proposal on post #63:Surprisingly no comments on my circuit proposal on post #61. Could even replace the zeners with fixed resistors as they are only there to fix the gate/ source voltage.
Sorry, I missed that amongst the other posts.And I am intrigued by the simplicity of it. I haven't tested it yet, but I will. Thank you!
No problem! I am just wondering two things about your circuit:Sorry, I missed that amongst the other posts.
Yes, it should. Looking again at my circuit, I would alter it slightly, see attached image.1. Does it work even if H3-1 and H3-2 switch polarity? I can't visualize that in my mind.
I would connect a varistor across the coil L1 in my diagram. Stops the transient there in its tracks.2. If I apply a varistor to protect the MOSFETs as we discussed (by clamping it to the drain and source), will I need to do anything to protect the Zener as well from possible voltage spikes coming from the magnet?
Oh, yes, that's actually the best way to do it from what I have read around as well. Unfortunately with my current setup, it is very hard if not impossible to put a varistor that way since the MOSFETs in this circuit control one pole of the magnet, and the other pole is controlled from another circuit where some solid-state relays are located, on a separate board (that's due to the overall design of the project, to be modular and scalable).Like this...
Awesome circuit, it looks great to me. I'll make a prototype and test it! Thank you!Yes, it should. Looking again at my circuit, I would alter it slightly, see attached image.
Thank you! I will!Looks good - Let me know how it goes![]()
Yes, my mistake. It was late when I drew the circuit.Just one question: I guess the value of R1 is still 220 ohms, right?
I don't think that's going to be a problem. The switch is in the 50ms range and it is not much repetitive (2-5x every 2 seconds max). But I can test and see. Thanks again!Yes, my mistake. It was late when I drew the circuit.
By the way, your alternating voltage from H3-1 and H3-2, what frequency is it? Just thinking that the MOSFETs are switching at that frequency, and if the gate turn off was too slow it would generate heat in the MOSFET.
Unfortunately not. But I am wondering if the small size of those components is playing any role. If you looked at their specs, it looks like they should work just fine, but there must be something else that prevents them to work without overheating compared to the other MOSFETs I used in the previous prototype.Do you have access to an oscilloscope?
It might be worth looking at what is actually happening
Good question... that was just for the sake of their small size. By looking at their specs, I thought they would have worked just fine, but I was clearly mistaken. Do you think that fact no power dissipation is shown on their specs is a sign that they may be weak on that front? Or do you see any other difference between those and the previously used ones that could cause them to get that hot?Any reason to go from a reliable part to a cheap unknown one?
Thank you, I didn't think to look around for other specs, appreciated!Another no-name lists PD as 1.2W.
http://www.21yangjie.com/style/pdf/low-voltage-mosfet/YJL05N04A Rev 3.0.pdf
Lower Drain-Source Voltage, higher Junction to Ambient and Drain-source on-resistance.
So... how would you suggest fixing that? Thank you!Long switching times would be my first bet.
