Why can't I flash my microcontroller?
SpoNNw
Joined May 25, 2020
12
Hi there, I need your help.
I am working on a project where I have been using the LaunchPad LP-MSPM0G3507 to test and debug my firmware.
Now, I have implemented my circuit hardware with the MSPM0G3507 microcontroller, but I’m facing a problem, I can’t flash it.
I was trying to use the XDS110 Onboard Debug Probe that came with the LaunchPad to flash my microcontroller, for debug interface I followed Texas Instruments hardware guidelines and datasheet.
Figure from page 73 of the MSPM0G3507 datasheet.
On my hardware I did pretty much the same.
On LP-MSPM0G3507 there is a connector J101 where this singnals are in as you can see:
Figure user's Guide MSPM0G3507 LaunchPad
And on launchpad Shcamitc we can see J101
Figure from LP-MSPM0G3507 Hardware Design Files
What I did was interconnect +3.3V, GND, NRST, SWDIO, and SWDCLK exactly like this.
I checked the solder joints and the debug interface on my hardware, and everything seems to be fine. However, when I try to flash my microcontroller, I get errors like this:
Code Composer:
Uniflash:
My question is: am I missing anything? Is there something I'm doing wrong here?
* I was wondering if NRST should be connected to the debug interface.
Thanks!
