Which oscilloscope is better
STP.Asghari
Joined Nov 22, 2022
12
KeithWalker
Joined Jul 10, 2017
3,615
You do not mention what you intend to use the oscilloscope for, so I am not able to give you an opinion.
Is there anything in the specifications that you don't understand?
STP.Asghari
Joined Nov 22, 2022
12
I mean more about the experience of using these devices and whether the specifications stated in the catalog are consistent with reality? I am especially interested to know about FNIRSI 1014D.
BobTPH
Joined Jun 5, 2013
11,636
The FNIRSI is certainly a bargain if you need the signal generator as well and it is good quality, which I have no way of knowing.
The bandwidth and sampling rate are the same on both.
SamR
Joined Mar 19, 2019
5,535
Look at the signal generator specs. I know that the one in my Siglent is voltage limited to less than my bench sig gen. It is handy for low voltage (5V or less) work.
