Where can one find these metal plates for mounting diodes ?
Lumenosity
Joined Mar 1, 2017
614
In the photo below there are four diodes mounted in pairs on metal plates.
These two pairs of diodes form a Diode Bridge rectifier.
I can find the diodes...but a Google search did not reveal a source for the metal plates they are mounted on.
Anyone know a source for these? Or maybe I'm calling them something different than they are commonly known by?
sdowney717
Joined Jul 18, 2012
805
Do you have an old PC PSU? they will have those heat sink plates in a variety of shapes made from aluminum, and will have solderable riveted ends to attach to a board.
Lumenosity
Joined Mar 1, 2017
614
Figure out what currents and heat you are dealing with and then use a standard bridge rectifier mounted on a heat sink. One way to do it.
I'm not 100% sure, but I think they may have done it this way in order to use ultra fast diodes.
The specific diodes used here are UF202 (HER203 is substitute I think)
I looked at some KBU bridge rectifiers and couldn't find recovery time specifications.
But I think Ultra fast recovery time is why they were done like this. Comments?
Lumenosity
Joined Mar 1, 2017
614
The plates are acting as heat-sinks, and are likely unavailable as a standard part.
Something like this may work.
Thanks.
Yes, those should work. I'd just need to get busy with the Dremel to make the feet so I could solder them to the board.
A little surprised such plates aren't readily available because unless I'm mistaken, this type of 4 diode setup is not uncommon?
sdowney717
Joined Jul 18, 2012
805
Thanks.
How about using an old copper penny? If you can find one. New penny is coppered zinc.
dl324
Joined Mar 30, 2015
18,490
A nibbler will make less mess.
These used to cost around $10:
You might be able to scrape the anodization off in spots on something like this:
Black bodies radiate heat more efficiently than bare copper.
Tonyr1084
Joined Sep 24, 2015
9,744
First time I've ever seen this - at least as best as I can recall.
Also don't understand the need for ultra-fast switching diodes. I'm seeing some rather large filter caps on the board; so are we rectifying a radio frequency? I've never seen that done before. But that doesn't mean it's not done - it might be. But then I'm thinking if it's radio frequency then wouldn't it be shielded? But hey! What do I know? Right?
Tonyr1084
Joined Sep 24, 2015
9,744
You would have to make them. Tinned copper preferably for thermal conductivity.
I have some sheet copper out in the garage. Was here when I bought the house. I suppose one could use sheet copper the likes of which I have, and it wouldn't have the fiberglass PCB material to act as a heat insulator. At least I'm thinking the copper sheet will have better heat dissipation than a copper clad PCB.
Lumenosity
Joined Mar 1, 2017
614
This is the information I was looking at.
https://electronics.stackexchange.com/questions/323507/bridge-rectifier-4-diodes-vs-single-chip
Silicon diodes do not turn off instantly. As the voltage across the diode goes negative, current still flows in the reverse direction for a short time, until the charges stored inside the diode are cleared out. When this is done, the diode turns off.
Different diodes have wildly different recovery characteristics, as shown in this scope plot:
The current does indeed go negative (the "wrong" direction for a diode) for a time which is called "recovery time". The red one takes longer.
In a DC-DC converter, it is crucial to have a diode that turns off quickly. Imagine using good old 1N4001, with its recovery time trr=30µs in a DC-DC converter running at 200kHz (cycle time 5µs). It wouldn't even have time to turn off. It wouldn't work at all. This is why DC-DC converters use much faster diodes
Lumenosity
Joined Mar 1, 2017
614
Tonyr1084
Joined Sep 24, 2015
9,744
This is sort of what I have in my garage. Plain copper sheet, no fiberglass to insulate the heat radiation from both sides of the copper sheet. Easier to trim and shape as well.
MaxHeadRoom
Joined Jul 18, 2013
30,868
Another simple cheap solution would be to cut a required length of thin wall 1/2" copper pipe and squash with vice and/or hammer.
lube the centre with flux before squashing and this could then be heated for solder to flow between sides.
Tonyr1084
Joined Sep 24, 2015
9,744
go to the hardware store and buy for a quid a copper pipe joiner.
Cut it down the center and fold it out flat.
That works too, but you're still cutting and shaping the copper. Sheet copper is already flat. All you have to do is cut it to the desired dimensions. You can even cut in some feet for soldering.
