When to use an Isolator?
brightnight1
Joined Jan 13, 2018
97
I'm planning on building a simple system with a microcontroller to turn a camera on, take a picture, and turn the camera off (perhaps some added functionality too). I was planning on using low side FETs to control the camera functions, but now I'm wondering if I should be using like a optocoupler to isolate the camera from the arduino. If the camera and Arduino are powered from different batteries the grounds will be connected. I guess I'm really wondering, why or why would I want to use an optocoupler in this type of situation?
MaxHeadRoom
Joined Jul 18, 2013
30,785
Generally it is not a problem to have the commons connected.
Often it is necessary where you want to maintain galvanic isolation from a earth grounded system etc.
Max.
Wolframore
Joined Jan 21, 2019
2,619
In this situation I don't see it being a necessity. It would be warranted in areas where you can damage yourself or the microcontroller.
SamR
Joined Mar 19, 2019
5,534
Anytime you are interfacing with a device using a voltage higher than 5VDC you should consider isolating it from the Arduino.
SamR
Joined Mar 19, 2019
5,534
Or even the stodgy ole 2N2222 BJT, although the 2N7000 logic input MOSFET is better up to 1/2A and FQP30N06L MOSFET for higher amps.
Kjeldgaard
Joined Apr 7, 2016
476
I have a Radio Remote Control for my Canon camera and the connections look like this:
If the camera and remote control each have their own battery supply, then I will not be worried about connecting them directly with a cable.
