When is a transistor too hot for its own good?
WBahn
Joined Mar 31, 2012
33,340
The resistor in the emitter circuit provides negative feedback.
Yes, but that was specifically not a part of this particular project's learning objectives. I wanted students to first deal with open-loop design problems so that they could better appreciate the effects of adding feedback later.
susanne
Joined Oct 29, 2014
7
Not if you want to make any money or stay in business. Now, if you are doing a project that has weight/size/cost budgets that will allow you to take this approach profitably, then the marginal savings in design cost (since you aren't spending time deciding whether to add a heat sink) may be worthwhile. But what size heat sink?
But if you are designing a product that has tight budgets in one or more areas and especially if you are designing something for a high-volume market that has competition, then you are being irresponsible to put heat sinks where they aren't needed -- to the degree that designing products that are not competitive in the market place is "irresponsible".
I agree. That's a comprehensive approach. I looked at it from a narrow point of view.
