what this component can be? resistance?
bertus
Joined Apr 5, 2008
23,006
The picture is very tiny. You can not read what is printed on the component.
As it has a line on one side it must be polarized.
As @MrChips said, it could be a diode or electrolytic capacitor.
A zener diode may also be an possibility.
Bertus
djsfantasi
Joined Apr 11, 2010
9,237
Wow! That’s a really small image.
Can you post another image, larger and clearer? Not necessarily closer, just larger. If you can, take the highest quality image that you can and crop it to show just the top of the component.
Thanks.
LAOADAM
Joined Nov 21, 2018
956
post-38.JPG the reading is '0' (burned?), I guess I found the location of fault, but can't figure out the value, two Dark blue rings. and can't see the first ring, should be Silver? or just two rings?
35,187
View attachment 175407 the reading is '0' (burned?), I guess I found the location of fault, but can't figure out the value, two Dark blue rings. and can't see the first ring, should be Silver? or just two rings?
Don't jump to conclusions so quickly.
An SMD component with two black rings can simply be a 0Ω resistor. Circuit designers have many reasons for installing 0Ω resistors in a circuit.
28,310
I have used SMD fuses that looked a lot like that. And the first picture looked more like a capacitor to me. But was the reading the same in both directions? That can provide a clue.
ALSO, how about a picture of the whole board, or at least some larger potion of it. More information will often lead to much better answers.
Ya’akov
Joined Jan 27, 2019
10,300
Looks like brown-black-black-silver, 10Ω 10%.
The large size would make sense for that value.
On the other hand, very hard to tell out of context.
28,310
Yak is correct. If you can trace out a bit of the surrounding circuit then a much better evaluation would be possible. One more thing is that by the shape of the part the circuit board is quite a few years old, since it has been quite a few years since surface mount parts changed shape to the more rectangular format. So probably the circuit board is not terribly crowded. So a clear photo will be able to provide some useful information.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
1. 'An SMD component with two black rings can simply be a 0Ω resistor. ' is reasonable, because I hooked up a pot and tested out the circuit only works when the R<150 Ω, and 10 Ω is OK;
2. 'You sure thats not a diode?' measured two directions all '0';
3. a large pictures here.
it is a wheelchair joystick board.
