What is this connector?
Ya’akov
Joined Jan 27, 2019
10,234
Welcome to AAC.
Modular connectors, like that one, use nomenclature like nPnC where P is positions and C is contacts. So your connector would be a 12P12C, also called 12x12. Unfortunately, the biggest I know of is 10P10C.
Does the handset actually use all those wires. It seems excessive.
What is the brand and model of the handset/radio?
SoundguyAL
Joined Nov 4, 2020
27
Thanks for the replies.
Ya'akov,
Thanks for that info. This is an Inmarsat JUE-251. There are 2 pins of the 12 that are not used.
Externet,
Thanks for the link.
The most ideal installation would require both male and female.
I would like to have a jumper from the main unit to a bulkhead connector which the handset can connect to.
See pic.
This may not be attainable as the 12P12C connector is not as popular as a standard RJ45.
Externet
Joined Nov 29, 2005
2,630
I believe the link shows both. As last resource, at some places you can sustitute one 12P12C with two RJ45 8P8C
Saw them at Alibaba too.
