what is the maximum non-repetitive peak current an isolated DC-DC CONVERTER module can handle?
BrokenPin
Joined Oct 1, 2023
44
I'm working with isolated DC-DC converter modules and have a question about their current handling capabilities.
While datasheets typically specify the maximum continuous output current, I don't see clear information about their tolerance for non-repetitive peak currents. like, how well do these modules handle short-term overcurrent situations, and is there a general rule of thumb or standard for determining the maximum allowable peak current?
Additionally, if a module features short-circuit protection with auto recovery, is it safe to assume it can withstand brief current spikes without sustaining damage? like for example a 5A current draw to charge the gate capacitor of a Mosfet.
Thanks in advance!
BrokenPin
Joined Oct 1, 2023
44
That sort of short term current surge would come from the capacitors on the output. The power supply would likely not even notice it.
Then what's the use of the 1W/2W dual output (15V / -3V) isolated DC-DC supply usually used with gate drivers. Is it just to power the high power side of the gate driver?
Ian0
Joined Aug 7, 2020
13,306
If the circuit is a flyback converter, then it will most likely have current mode control, so every cycle is current limited.
BrokenPin
Joined Oct 1, 2023
44
there is no mention in the datasheet or anywhere of the topology used for these Isolated Module DC-DC Converter
schmitt trigger
Joined Jul 12, 2010
2,273
* if I am understanding your concern correctly*
You are confusing two separate issues.
These dual voltage supplies are used for very high power IGBTs, which require a negative bias to properly turn off.
This fact doesn’t have a relationship with your original question, which is the current surge capability, which as Bob answered accurately, it is handled by the supply’s output capacitors.
If our answers don’t explain your concern, then explicitly indicate what issues you’re experiencing.
BrokenPin
Joined Oct 1, 2023
44
Yes, Bob already explained that the surge needed to charge the internal parasitic caps of the mosfet comes from the output caps of the supply ..
Previously, I thought the dc dc module needs to supply the surge current to charge the mosfet gate caps (and thats in the Amperes range).. but now i just need to confirm whether the DC-DC module only needs to provide power for the gate driver IC!? so that i will be able to size it right ..
Ian0
Joined Aug 7, 2020
13,306
No, not quite: the DC/DC converter has to supply the average current used to charge the gates plus the gate driver IC quiescent current.
The average current = Qg.f
L Analog & Mixed-Signal Design 5
