what is the inductance L for this coil?
Ian0
Joined Aug 7, 2020
13,232
Pu
Yes I had the idea actually. XL=2*pi*F*L and V=I*XL
feed 220v. measure the current while playing with F.
make a few points and get the average. right?
Put it across the output of the variac, and increase the voltage from zero until the current = 0.75A. Measure the voltage.
Then you can work out the impedance, and you know the frequency, so you can work out the inductance.
[Edit] for better accuracy check that the DC resistance is not significant compared to Z. If it is, then you will have to work out the reactance by Z^2=R^2+X^2
33,084
A variac doesn't change the frequency, so how are you planning to play with F?
idir93
Joined Jan 10, 2018
27
What happens if I inject more current (by either increasing the voltage or reducing the frequency or both at the same time)?
Danko
Joined Nov 22, 2017
2,227
Мeasure resistance R of coil on DC.
Сonnect coil to AC voltage source.
Measure AC voltage on coil and AC current through coil.
Calculate impedance Z=V/I.
Calculate inductance using calculator:
https://www.omnicalculator.com/physics/inductive-reactance#unit-of-inductive-reactance
Inductance will different on different voltages, because
magnetic characteristics of ferromagnetic core are nonlinear.
Edited: some changes in calculation made.
Ian0
Joined Aug 7, 2020
13,232
Yes I understand that. I have a different question now:
What happens if I inject more than 0.75A?
The odds are that 0.75A is a thermal limit. If you exceed that, it will get too hot.
It could also be that 0.75A is the saturation limit. If you exceed it, then the inductance will reduce.
The inductance at zero current will be higher than the inductance at 0.75A
