Yes I had the idea actually. XL=2*pi*F*L and V=I*XLDo you have a variac? If so, it's easy to measure.
Put it across the output of the variac, and increase the voltage from zero until the current = 0.75A. Measure the voltage.Yes I had the idea actually. XL=2*pi*F*L and V=I*XL
feed 220v. measure the current while playing with F.
make a few points and get the average. right?
A variac doesn't change the frequency, so how are you planning to play with F?Yes I had the idea actually. XL=2*pi*F*L and V=I*XL
I have a frequency converter with me. it is connected to it actually.A variac doesn't change the frequency, so how are you planning to play with F?
Then that does open the door for a wider variety of measurements.I have a frequency converter with me. it is connected to it actually.
The odds are that 0.75A is a thermal limit. If you exceed that, it will get too hot.Yes I understand that. I have a different question now:
What happens if I inject more than 0.75A?
