What is the alternative SCR thyristor to use?
pumpkin king
Joined Jan 22, 2016
8
Hi all,
I'm attempting to repair a driver module that controls motors on a CNC machine. I've discovered a GE C147S thyristor has died and shorted out. I'm no expert when it comes to SCR's
From what I can find, the GE C147S is an old thyristor with a TO-65 casing (I think, the bolt is a quarter inch or about 6.5mm) from the 70's. Is there an alternative new thyristor I could use that I can easily buy as I cannot find this thyristor anywhere online.
Data sheet for GE C147S
Repetitive peak off-stat voltage VDRM - 700v
Repetitive peak reverse voltage Vrrm - 700v
I max 63Amps
Ig ≤300mA
Ug: ≤3.5V
MaxHeadRoom
Joined Jul 18, 2013
30,759
Check out the listings equivalent for Teccor, now Littlefuse, they will have a TO-220 to TO-3P that can be used.
If no direct equivalent shown, just use the current/voltage specs to get in close.
Max.
