LEDs flicker on triac dimmer, alternative solutions?
LikeTheSandwich
Joined Feb 22, 2021
216
I have some cheap LED lights, they say they're dimmable, and there's zero flicker when it's turned really low or really high. But for the middle 75% or so there's flicker. Total wattage is about 165~170. I don't know what it uses as a driver since that portion is encased in molded plastic, but it seems to feed a very solid 120VDC output. So does anyone know off hand of a 120VDC 200W PWM controller that could fit inside a standard home switch box (I would insert it between the LED driver and LEDs) or a relatively simple circuit design for one, with or without a microcontroller? I have some experience building circuits like this and programming with Arduino-compatible microcontrollers, but not enough to design this sort of circuit on my own (actually I probably could, but dealing with this high of voltage I'd rather use something pre-made or a guide someone might have). Thanks!
EDIT: If you aren't aware of a pre-built solution for this, does anyone know of a MOSFET that can handle 120V with a gate voltage of 5V or less to make building a circuit easier/simpler?
Sensacell
Joined Jun 19, 2012
3,789
Some LED fixtures are just not dimmable- period, at least not in a way that would be visually acceptable.
Here is an idea:
schmitt trigger
Joined Jul 12, 2010
2,288
Divide and conquer.
You don’t know and we don’t know whether the issue is with the lamp or the dimmer.
Get yourself a different dimmable lamp, preferably different vendor or wattage, and test it with the dimmer.
Then you will know.
Divide and conquer.
LikeTheSandwich
Joined Feb 22, 2021
216
Divide and conquer.
Then you will know.
Divide and conquer.
Good advice, I'll try that later this week. I'll also pick up a different dimmer switch to see if that helps. Thanks!
