alternative to gtop010 module
lichurbagan
Joined Jul 4, 2025
137
The Gtop010 GPS module is discontinued and unavailable.You can replace it with small Arduino-compatible GPS modules.
The u-blox NEO-6M is reliable and widely available.It outputs NMEA-0183 data over UART.
The u-blox NEO-M8N supports GPS, GLONASS, and Galileo. It has faster fix times and higher accuracy.
Adafruit Ultimate GPS Breakout PA1010D is compact and efficient. It supports a 10 Hz update rate and external antenna.
ATGM336H is very small and suitable for tight spaces. Use libraries like TinyGPS++ or Adafruit_GPS for parsing. Ensure voltage levels match your Arduino logic requirements. Place antennas with clear sky view for best reception.
