Any one suggest me alternative power supply of below pic
vipul akbari
Joined Jul 8, 2025
17
hello everyone
this internal power supply of creative inspire t6300 .no output power here so i want to bypass this power supply. if i know output of this board then i buy a same voltage and current rating adapter
thanks
BobTPH
Joined Jun 5, 2013
11,488
Easy to measure the voltage. Current would be more difficult since it varies with the audio being played. If you know the max power output, you can estimate it. If the amp is type D, the current will be close to P / V. If AB, maybe 50% higher.
vipul akbari
Joined Jul 8, 2025
17
Thanks for reply
This board is totally damaged .i know only input power 100~240 ~50/60Hz current 600-350mA
27,360
Should be DC, the four diodes on the top left look like rectifier to me, you can check their connection.
What you have so far are GUESSES!!
What can be simply verified is that the output is indeed a DC voltage, because one pin of the output connector is marked as positive.
For an additional clue, the TS can look at the voltage ratings of those three capacitors closest to the output connector. The voltage will not be greater than that.
Measuring the output voltage of a dead power supply is not likely to provide any useful information.
meth
Joined May 21, 2016
302
To a certain extent that is a guess too...
@vipul, they meant see if there is any marking on the board that was taking power supply from this board, or the other end of the cable that was in that white connector.
Externet
Joined Nov 29, 2005
2,628
Tell us the markings of the electrolytic capacitors by the bottom of image, and the markings on that 3 pin black part next to the output, and on the heat sinked bottom left.
vipul akbari
Joined Jul 8, 2025
17
Dear sir
There are 2 capacitors closest the out put . 1 capacitor is 25v 1000uf and second capacitor is 25v 470 uf .
34,714
May I use 24v dc 2amp and check again ?
No.
I suspect that the power supply required is 12 VDC for Creative Inspire T6300 PC amplifier.
You would need at least 5 A @ 12 VDC. Try this first before going to a higher voltage.
A 12 V lead acid battery will tell you if this is the correct voltage.
vipul akbari
Joined Jul 8, 2025
17
No.
Dear sir
Thanks for reply ,
I asked about voltage and current by mail so they send me just inputs voltage
