what happen to the rest battery voltage when using voltage regulator ?
38,814
now im completly confused
In a shunt regulator the current through the resistor to the zener always carries the same current since the voltage across that resistor is constant, being equal to the source voltage minus the zener voltage.
The current is just divided between the zener and the load.
Thus the more load current, the less zener current, and the better the efficiency.
At low load currents, the zener is carrying most of the current and the efficiency is low, since the supply current hasn't changed.
Make sense?
andrew132
Joined Feb 2, 2017
96
Make sense?
yes make sense
lets say the load resistor is 500ohm and Vz=6v R=200ohm Vin=12v what is the efficiency ?
WBahn
Joined Mar 31, 2012
33,192
yes make sense
First thing to consider is whether or not this is even operating as a regulator.
Remove the zener and figure out the voltage across the load without it. If that voltage is less than Vz, then the diode might as well not be there.
If it IS in regulation, then consider the following:
What is the current from the supply?
How much voltage is across that series 200 Ω resistor?
How much current is in the load?
What is the power being delivered to the load?
What is the power being delivered by the supply?
What is the efficiency?
andrew132
Joined Feb 2, 2017
96
Current drawn from battery is 0.03A @ 12V
Current drawn from load is 0.012A @ 6V
Efficiency = ( 6V x 0.012A ) / (12V x 0.03A) x 100 = 20%
when i change the resistor of the load to 20 ohm IL=0.3A that more than the input current
why the current of the load is more than the input ? can you explain to me please
WBahn
Joined Mar 31, 2012
33,192
when i changed the resistor load to 20ohm the current is 0,3A
What was the first thing that I said?
With a 200 Ω series resistor and 20 Ω load resistor, the voltage across the load is (12 V)(20 Ω / 220 Ω) = 1.09 V. Since this is less than the Vz of 6 V, the circuit is NOT in regulation and the zener diode might as well not be there. So the current through the load is 12 V / 220 Ω = 54.5 mA.
What is the largest value that the series pass resistor can be and have the circuit in regulation? Hint: This means no load (zero load current) and just the 100 mA minimum zener current I stipulated in the problem?
