what happen to the rest battery voltage when using voltage regulator ?
andrew132
Joined Feb 2, 2017
96
i was wondering what happen to the rest battery voltage while using regulator
does that will make the discharge faster ?
35,299
Assuming that you are referring to a linear voltage regular, there is no change in the discharge time of the battery.
If the load needs 1A, the battery still has to deliver 1A at the battery voltage. Any excess energy that is not used by the load has to be given up as heat in the linear regulator.
MrAl
Joined Jun 17, 2014
13,893
Do you actually mean the rest voltage or the "rest of" the voltage.
If you mean the rest voltage, then it drops because the regulator always draws some current. So the self discharge would appear to increase which would discharge the battery faster than without a regulator. Sometimes this effect can be minimized by using a regulator appropriate for the application.
andrew132
Joined Feb 2, 2017
96
so there a power loss .
if i have 12v battery and regulator 5v if i have load 5v @1A the run time is the same if i have 12v load @1A ? is that right ?
35,299
No, it doesn't change if you use a zener diode. The excess power must be given up as heat in the zener diode and in the series resistor.
The battery still has to deliver the full current at 12V.
dl324
Joined Mar 30, 2015
18,523
how to calculate the efficient
The rule of thumb is that the current in the zener should be 10 times the load current. With that information, can you calculate efficiency?
We can't because you don't provide enough information; unless you want it expressed algebraically.
