What can happen to a PCB burnt during hot air soldering?
Younes Thabet
Joined Jan 9, 2019
152
Hello all,
I was soldering an SMD component and I accidentally used a higher temperature and airflow to solder it so I burnt the PCB and a bubble appeared around the area as seen in the image below.
Is this bad? will this issue affect the functionality of the PCB?
What can I do to fix this?
Thanks,
Ian0
Joined Aug 7, 2020
13,312
It’s not good, but if it is a single or double sided board, it will probably have survived as there are no tracks in the vicinity of the bubble.
A multilayer board might not have fared so well.
dl324
Joined Mar 30, 2015
18,520
Younes Thabet
Joined Jan 9, 2019
152
It is probably a 4 or 6 layer but I can see that the area affected has nothing beneath it .. no traces no copper fils ..
So I hope the bubble doesn't spread .. can it btw!?
I have used a tweezer to pop the bubble ! I don't know if thats good or not !
