What Electronics Myths Did You Believe Were True?
kanya05
Joined Aug 20, 2026
I was talking about electronics with a friend recently and we got into some common myths.
“Leaving a charger plugged in wastes a lot of electricity, right?”
“Not really. It does use a tiny amount of standby power, but usually very little.”
“Okay, what about higher wattage? Higher wattage means better performance?”
“Not necessarily. It depends on the device and what you're actually using it for.”
Made me wonder, what other electronics myths have you heard that turned out to be completely wrong?
That current in a wire is electrical energy.
ronsimpson
Joined Oct 7, 2019
4,878
Electricity flows like water in pipes. It flows from + to -. Electricity is "magnetic" in that current in a wire will want to cause current to flow in a nearby wire. (transformer & inductor & motor theory) When you put electricity in a wire it pops out the other end.
My dad knew next to nothing about the subject, but he taught me this. By 3rd grade I was making things.
By 9th grade I was teaching the shop classes in electronics. (simple kit building and theory) By then I knew Electrons frow 'uphill' to the +. Try teaching that to farm boys.
I still teach water flow theory, (fully knowing it is wrong) when the audience knows nothing.
-----Dad had a 1940's version of this picture, from an army manual.-----
Put a magnet in the back pocket of the "Amp person" and it almost works.
38,932
One I heard from the early days of electricity use in the house was that you needed to put tape over the unused outlets so the electricity wouldn't leak out.
A common misconception often seen here is that volts (potential) can be at a single node without any reference point.
They have difficulty understanding that, unlike current, voltage is always between two nodes.
Another is that current can flow without a complete return path to the source.
Futurist
Joined Apr 8, 2025
950
Perhaps the biggest myth was that magnetic fields are a distinct real "thing", that one came as an eye opener.
38,932
Well they do a lot of interesting stuff if they are an imaginary "thing". :D
Or are you referring to the observation that a magnetic field is just the relativistic effect of a moving electric field?
Futurist
Joined Apr 8, 2025
950
Yes, that's what I'm referring to, I was stunned when I first began to understand it, the magnetic field around a current carrying conductor.
Continuous steady state current.
Futurist
Joined Apr 8, 2025
950
It's pretty deep, seems the field actually is real, not just apparent (which is what I kind of thought). I'd like to study it more, get a handle on the tensor representation of the thing which it seems is powerful and elegant.
