What does Voltage tracking mean?
AlbertHall
Joined Jun 4, 2014
12,637
Commonly, voltage regulators contain a voltage reference.
This one uses an external reference so its output voltage tracks the reference it is supplied with. If the reference doubles, the output voltage doubles. The output may be less than, equal to, or greater than, the supplied reference voltage.
Electronic_Maniac
Joined Oct 26, 2017
253
Thanks. Can you give an example using numbers (Voltages at the Adj pin and Vref pin) with the above mentioned part? Please
