I am currently reading this experiment that was done to investigate electrostatic forces. In broad terms, it is creating a capacitor by placing two washers parallel to each other and connecting them to a power supply.
However, at one point in the procedure, it says "Use one of your MMM connected across the output of the HVPS to read the HVPS output (the right MMM in Figure 3)". I don't know what "MMM" means and wasn't able to find much on the internet either.
Here's a link to the experiment: https://ocw.mit.edu/courses/physics...ntal-focus-spring-2005/labs/experiment_ef.pdf
Here's a screenshot of the procedure:
Thank you in advance!
