What current is that transformer (noobie question)
AlbertHall
Joined Jun 4, 2014
12,640
You can parallel both windings to get 15VAC at 2A. If that is fed to a bridge rectifier with a smoothing capacitor that will give you around 20V DC and an RMS transformer secondary current of 1.61A, so that's OK.
The transformer voltage is much higher than is actually needed though. The output power is 5W (5V @ 1A) and the regulator needs to dissipate 15W of heat ((20V - 5V) * 1A). You could use a smaller and cheaper transformer or, to keep the heat down, use a switching regulator.
AlbertHall
Joined Jun 4, 2014
12,640
Correction [edited again] to that: You need 2A DC output but that will 3.2A RMS secondary current which will seriously overload the transformer.
LesJones
Joined Jan 8, 2017
4,521
Hi KISS,
I do not agree and neither does the information in your link. For full wave rectification with a capacitor output filter it states
V (Peak) D.C. = 1.41 X Sec. V A.C.
V (Avg) D.C. = 0.90 X Sec. V A.C.
I D.C. = 0.62 X Sec. I A.C.
So the AC current is about 1.6 times the DC current . (1/0.62)
Les.
Dodgydave
Joined Jun 22, 2012
11,395
Hi everyone, I'm making a linear power supply for my computer audio system, suitable for HDD or network cards.
The psu needs to deliver 5vdc and 2A minimum.
My toroid transformer Y236103 has 2 secondarys and is rated at 1A on the manufacturer's website http://www.avellindberg.com/transformers/y23_range_specs.htm
My question - is that the combined total or can each secondary deliver up to 1A?
Just use the 5V rail from your computer Atx psu...
billgr
Joined Jul 11, 2019
8
That's exactly what I'm trying to avoid. I want to provide _clean_ power to these components and try not inject any noise back into the other components. ATX power is convenient but not ideal for my application.
I thanks for the replies and the links. I'm getting the gist of it now. I don't have the circuit diagram (only the pcb) and I need to determine whether its full wave rectification and then I can order a suitable transformer.
billgr
Joined Jul 11, 2019
8
I need 3.22 A for supply of 5vdc 4A
A 50VA transformer with 12 vac secondarys will supply
50va / 12v = 4.17 A (more than needed)
Va = 0.9 * 12 = 6.75
Vp = 1.4* 12 = 10.5 (so I need at least this right?)
AlbertHall
Joined Jun 4, 2014
12,640
(1) 50va / 12v = 4.17 A (more than needed)
(2) Vp = 1.4* 12 = 10.5 (so I need at least this right?)
(1) is true providing the rectifier isn't followed by a smoothing capacitor. If it is then the maximum continuous current is divided by 1.6, so there is only 2.6A
(2) 1.4 * 12 = 16.8V
AlbertHall
Joined Jun 4, 2014
12,640
