What connector is this?!
Ktfifty
Joined Oct 25, 2022
I cannot for the life of me figure out what this connector is called. It’s extremely flat and has no buckle.
I lost the other side of this connector.. I want to replace it. I sincerely appreciate any help.
Ian0
Joined Aug 7, 2020
13,131
I was guessing at JST because of the colour. Yes- I know it's white, but JST seems to have its own unique shade and density of white which makes it immediately identifiable.
Ktfifty
Joined Oct 25, 2022
It’s for a scanner alarm light for cars! The connector is flat and doesn’t have any buckle. Brand of the light is varad
Ktfifty
Joined Oct 25, 2022
What is this used on? It might help in finding it.
Also, consider re-terminating with something more common?
I was thinking about doing that. I’m really bummed out that I lost it and can’t find a replacement. I’d ideally like to find some kind connector that is just as small/flat (no locking pin). Any suggestions?
thank you all!
tyro01
Joined May 20, 2021
87
I checked the entire JST catalog and found no connectors similar to the one in your picture.
Basically JST connectors have a simple structure but secure locking mechanism.
I use google image search using following keyword "wiretowire connector 3 pin".
I don't know where those parts can be purchased. It would be best to ask the manufacturer's representative, but Alibaba is probably the most likely source if you need a quantities.
